Heres my latest. :)
Im fed up with the default Windows Taskbar and start menu,I wish Microsoft would make diffrent themes for it as with all the themes you get it does not really change them other than the background. :cool:
Too Many Icons Just Piss Me off! It Just Gets Too Hard To Find Stuff!
So I Am Very Oraganized :P
And I Just See Windows Seven As Just A Patched Version Of Vista So I Could Care Less If i Had Windows Seven!
Motorcharge,where you get your Taskbar theme from? :)
My Current. :P
This thread used to be very active. :cool:
I decided to redo my Ubuntu. I have 2 panels now. One on each monitor at the top. I moved the open window manager to the bar on my secondary monitor. Pretty happy with how it turned out.
Heres my latest. :)
You can change the start orb. You have to mess with the registry and a bunch of other stuff, but I did it on another install and it looked awesome.
Cleaned up m Desktop.
:D
This is my Windows 7 Screenie, will post a Ubuntu one soon.
But I gotta say my Ubuntu 11,04 is way more beautiful than any OS I have ever seen.
I even find it more seductive than MAC.
Just so neat and clean and simplistic :D
Here's Mine!
Ubuntu 10.10
Elegant GNOME Theme
To install this theme in Ubuntu 10.10 just do the following:
Open a terminal and run the following commands:
sudo add-apt-repository ppa:am-monkeyd/nautilus-elementary-ppa
sudo apt-get update && sudo apt-get upgrade
nautilus -q
sudo add-apt-repository ppa:elegant-gnome/ppa && sudo apt-get update
sudo apt-get install elegant-gnome ttf-droid
then go Applications -> Accessories -> Elegant Gnome and select install pack
After reboot go to System -> Administration ->Update Manager and update otherwise nautilus UI will be missing icons.
That looks really nice fordsvtparts,Im tempted to install Linux again and have a play around with it.
You dont see many people posting shots of linux on here. :)
