Hello. I have 4 raid max 120mm fans with the leds mounted in the circumference of the fan. They have 6 pin connectors. I bought a Comte case that didn’t come with the controller. I ordered a COOLMOON 6 pin controller. Except it’s different size. That was a bitter point I learned. The raidmax fans have plugs 15.5 mm wide. RAIDMAX no longer sells the controller for my fans. Haven’t had much luck hunting one down. So now I’m also researching ARGB fans that will work with the Coolmoon 6 pin controller I have. Prefer fans with leds around the circumference Any ideas which fans fit and I can use? I’ve built computers hobby since i386 was around. But this led and ARBG is all new to me. Any help is much appreciated. Thank You
