Why the heck are you using 98 SE?
I thought it was Windows 2000 at first, but they all looked the same before XP, only real differences were the shades of grey which were used I believe and the UI of explorer.
ashley, I get what he was saying. The way he said it is patronizing. It is really none of anyones business WHY I run anything. The question I had was already solved. LEAVE IT ALONE now.
And no, it is not all the same except the colour before XP. If you look at the fine details, just the taskbar will tell you exactly which windows you are looking at.
OK whatever. I was just pointing out that there was no need to explode.
wolfeking,I really think you need to calm down a bit,All spirit done was ask you a simple question...no need to go off on one.
Thats it now please,Give it a rest...the question has been answered. :)
Sure am :D I like to keep things organized and fences has loads of customization so I just really like it ;)
Thanks :D as does yours!
Mines a bit OTT with colour but, I like it!
I like the red start button and black taskbar. Looks a bit like the Zune theme for XP which had an orange start button and a black taskbar.
Looks cool! :D
Looks cool! :D
Thanks, I wanted to run Windows 7, but it's unstable when both of the CPU cores are enabled. :confused:
