Hello,
I have a Gigabyte Motherboard with 2 ethernet ports on it.
The first/top one doesn't work and the second does.
MB: Gigabyte EP45-DS3
Ethernet: Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabyte Ethernet NIC (NDIS 6.0)
I have updated the drivers and it doesn't work. When I try to uninstall the drivers to reinstall them, the uninstaller gets stuck right when he starts. Also in device manager disabling or removing them freezes the task.
My ping is very high on Windows Vista. Also on a laptop with vista it is high. But on another computer with XP it's as it should be low.
All on the same modem.
Thank you,
Oekoeloe
Thank you,
Oekoeloe
