Fatback
Hmm, not sure, i guess you will find out once you have itLink comming in a second for psu
Cool If I need any help once I get it then I'll just post a thread.
Would need to use molex->6pin, but like i said, the 750w corsair or pcp&c would be the best if you can afford them.I thought that the 4870 need 2 6-pin connectors that means I would need 4 6-pin connectors for 2 4870 but the first two PSU only have 2 6-pin connectors.
Pcpower and cooling i would go for, cheaper and uses seasonic internals, slightly better than the channelwell internals used by corsairYea maybe I will spend a little more and spring for the corsair. I heard it wasn't a good idea to use the molex->6pin connectors for GPUs.
Oh, i was saying that the pc power and cooling was cheaper than the corsairThere not cheaper not on newegg any ways mabe I'll just go with the OCZ stealthxstream for now and get a really expensive power supply later. I plane on doing a 3K computer build in about a year once I get finished getting my computer technology degree and get a full time job.
