If it doesn't work, make sure you posted the information in this window and not in this window. The second is alternate, the computer will fall to that one if DHCP does not work for some reason.
The numbers for the laptop are as follows:
IP Address: x.x.x.y
Subnet Mask: 255.255.255.0
Gateway x.x.x.x
DNS Address x.x.x.x
Where the x's are your router's IP Address and y is one number different than your desktop computer or your router's final number (it doesn't matter which you choose except it cannot be over 255 and no other computer on your network can have it).
ok well did that and what i get is (connected but no acces to a web page.) so i checked my router and shows my lappy is attached and the physical address match.Also all i get is packets sent none recived.
