I've heard some really great reviews on the Q6600. I chose that one.
I see Newegg have a OEM Q6600 w/no fan for $182.99. Man, these CPUs, just keep going lower in price!
[-0MEGA-];966254 said:The Q6700 is much cheaper now, and better priced for it's performance. I would recommend the Q6700.
the difference between 45 nm and 65nm is feck all compared to the price difference between the 2.
the q6600 kills the other's when its bang for buck.
this is an untrue statement
Q9300=284.99 on newegg(274.99 OEM)....higher native clock(2.5), higher native FSB(1300), 45nm tech (allows for higher OC generally), lower power consumption at highest maufacturer spec
Q6600=219.99 on newegg (no OEM available at the time, which is usually the case for this chip)...has slightly more L2 cache, which is misleading in this case because the 6600 has 2 L2 modules equalling 8Mb while the 9300 has 1 L2 module for 6 Mb, higher voltage which in general means higher temps, other wise they are very similar.
I think the benefits of the Q9300 far outweigh the measly $65 dollar price increase (at least it doesn't cost a grand like the much over-hyped extreme editions)
and for people that think the 20nm space difference in the architecture doesn't make a difference, maybe you should read up on thermodynamics in electronic engineering before you open your yap again.
mobo-ASUS P5E3 wifi ap@n
CPU-Intel Q9300 @2.5GHz
RAM-4GB Patroit EP DDR3 1333 (2 DIMMS)
HDD-WD Raptor 150GB @ 10,000rpm
VGA-ZOTAC Geforce 9600GT 512MB, 256-bit
PSU-Cooler Master Real Power Pro 750W
Why don't you OC your Q9300?
yes it is possible even on air and make shure you get a good overclocking motherboardThanks for everybody's input, I see Newegg have now priced the Q6600 at $214.99, truly outstanding price now.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-CPUs+%2f+Processors-_-intel-_-N82E16819115017
Personally I think Ill go for a Q9300 or Q9450 processor as it has to be future proof for a couple of years, also, I have heard the Q9450 can be overclocked to 3.8GHz stable? If this is true, it would be such a bargain.
i recently (just before i built my new comp) broke my cooling fan (am using the stock fan now) and am waiting on the new one to arrive before i start OC'in it, because while im sure i could take it to at least 3GHZ with the stock fan, am i going to take any chances? no.
Indeed, I definitely want a x38 or x48 motherboard at minimum.
