NEED help overclocking
Ok i got it up to 3.2Ghz and it wouldnt boot it just kept loading the post screens and then before it got to the windows loading screen it would shut off and kick out to the post screens again and it would keep doing that so i upped the voltage a bit and now it boots. But like the windows loading screen like comes up and sits there for a bit then finishes loading like the pic and then the bar starts moving like its loading. Plus when i'm listening to music and get into PC Probe II the program that came with the board to tell you information it turns the wave volume to zero so i cant hear anything. Whats up with that? Plus how do i tell if its gonna run stable at what i have it set at??
Whats the voltage currently set to, and what does the hardware monitor show it to be? I would back the speed down slightly and see if it's any more stable, because as it is now it sounds like under any type of load it will cause instability.
Ok i backed it back down to 3.0Ghz and the voltage is set at 1.288v but it shows in the hardware monitor as 1.25v. And when i get into pc probe it still turns off the wave volume to zero but thats the only problem i'm having. So i cant run it at 3.2Ghz stable then? or what? What can i all do to tell if its stable or not?
Have you tried setting the voltage to 1.500V?
I know you have a different sound card (onboard?), but even with my X-Fi I need to reinstall the drivers every time I turn on the computer, or else the sound wont work.
So it would turn off the wave volume for you too then you downloaded it off of there site and reinstalled it and now it works fine?
yep it used to do the same thing it did 4 u but I unistalled it and downloaded the latest one from asus's website and now it works
edit: I just opened it up and it still brings the wave volume down a little but at least it doesn't mute it
