Jet
Problem: My GPU client has stopped running. I double click it and it pops up then goes away. So I downloaded the new 5.91 and tried installing that but get the same thing when clicking run. It pops up then goes away. My regular folding clients work fine still. The only thing I've done is installed Java. Could that be it? It worked earlier just fine. Java hmmm.... Any thoughts?![]()
What drivers are you using?
And, I also figured out why you can run your GPU with lower CPU; it is because I have a 256MB card compared to your 512MB.
