MatrixEVO
Here I have an Aspire 520 watt PSU for sale... $30 US dollars plus the shipping within the US (no more then $10). It's not too old and it is in great shape. I am selling it because I have a huge case and need longer cables.
Type
ATX
Maximum Power
520W
Fans
3
PFC
No
Main Connector
20+4-Pin
Dual +12V
Yes
Power Good Signal
100-500ms
Hold-up Time
>10ms at full load
Efficiency
>70% under max range load
Over Voltage Protection
YES
Overload Protection
YES
Input Voltage
115/230 V
Input Frequency Range
50/60 Hz
Input Current
10A @ 115V, 5A @ 230V
Output
+3.3V@30A, +5V@32A, +12V@35A, -5V@0.3A, -12V@0.8A, +5VSB@2A
MTBF
100,000 hours at full load/25°C
Approvals
CB IEC 950/ TUV EN 60950/ UL 1950/ CSA 950
Features
Fan speed controller, full cable UV green Sleeves, 2.0mm aluminum casting; 1x 20/24pin Main Power, 1x ATX12V 4pin, 8x Peripheral, 2x Floppy, 2x SATA
JUST POST A REPLY IF YOUR INTERESTED!!!
Type
ATX
Maximum Power
520W
Fans
3
PFC
No
Main Connector
20+4-Pin
Dual +12V
Yes
Power Good Signal
100-500ms
Hold-up Time
>10ms at full load
Efficiency
YES
Overload Protection
YES
Input Voltage
115/230 V
50/60 Hz
Input Current
Output
MTBF
Approvals
Features
