Yah, it helps a lot with loading times and increases FPS and loads textures better. Amazing huh?Really? That's weird, since the files it uses are all stored on the HDD. It only requires you have the game disc in, so it know's you own the game...
Yah, it helps a lot with loading times and increases FPS and loads textures better. Amazing huh?Maybe only because my HDD is a Maxtor Dimond Max 10 3GB/s but hay, i could be wrong.
Well, I'm not totally convinced... The files are stored on your HDD, so using a Virtual Drive vs Physical Drive would make no difference (unless the game actually does require files from the disc [which most games don't]).
i have 2
1 dvd rom
1 dvd ram
its not spicifically a DVD-RAM drive, but the DVD drive still has to support it
who knows? maybe the burning lens died and now all it can do it do DVD-RAM?
