Totally_Lost
I have a modem / router that connects to my desktop by either of two ways:
1. WiFi connection.
2. Via a USB port.
The modem / router has an internal antenna. But, with it not having an Ethernet LAN port, I do not have the option of connecting it to a more powerful router. The SMA jack is to connect to the external 9dB gain antenna.
Do they make WiFi routers with USB WAN ports? Or, is there another way I can connect this modem / router to other routers? I need to connect to other, more powerful WiFi routers - with external antennas, to cover more of our farm. Worst case, if I can just connect to one other router, would be great. The internal WiFi antenna in this particular unit just isn't going to cut the mustard.
Thanks for any assistance you may provide.
1. WiFi connection.
2. Via a USB port.
