I just cannot get used the lack of a Start Button on Windows 8!!
Here's my wallpaper on Windows 7. Excuse the sticky note. :/
I never bother with additional themes for Windows 7. The default one looks nice. :)
It's just a bit more transparent. The start button isn't part of the theme. I just used the start orb changer and found an orb I liked on DeviantART.
XP is still brilliant,Not sure about X64 bit though i had issues with it..Still using XP pro SP2 on 2 other machines here.
My current desktop.
Loving these temps idle. :D
My current desktop.
Do I see Just Cause 2 there? Awesome game! :)
Umm I don't really like the 32-bit XP all that much these days, but for some reason I like XP x64. My only issue with XP x64 is trying to install software which requires at least XP SP3. As XP x64 is based on Windows 2003, there is no SP3 for it, it only goes up to SP2, so any software which requires XP SP3 to work usually doesn't work in XP x64.
it doesn't recognize your 16gb of ram :P. Can you try to run the benchmark on it? Would it make a difference?
It doesn't detect 16GB of RAM because it's running in a VM and I've only allocated 4GB to it. It will detect up to 128GB.
I have tried our bench in XP x64, it works but there are some issues with how the UI actually looks.
