Odd, I don't see mine.
I removed it along with several others.
because this is a "Post Your Desktop up" thread, Not "post the background you use for you desktop"
Which are just plain,boring images and not a desktop screenshot
Which are just plain,boring images and not a desktop screenshot![]()
is that on 7 or 8, how/where did you get that stuff?
I see
He just wants to see what porn you have saved to your desktop![]()
Good old XP Pro
On the laptop,Celeron 575 2ghz,2gb ram,5400rpm hard drive.![]()
Nothing wrong with that! I enjoy how clean XP is... None of these fancy gradients and windows aero crap.
scolls,
Is that a specific theme you have applied that gives it that OSX-style?
Cant get amymore simple than that.
So you use Linux much these days then Mihir or just to play around on?![]()
I have been using Linux for the past 3 years..
I generally use Linux for all my need except gaming and partial web development.
Still I play around a lot. I just recently tested out CentOS, ArchLinux, Fedora 16 and EasyPeasy. I use my netbook just for linux distro testing. But CrunchBang is the one for me. It is so fast and clean and easy to use. Though I would not recommend it if you are not too used to the command line, if you are using openbox only.
I have error 0x80070715 . what i should do for that..
Any recommend?
