It's not just the speed, it's the latencies. It makes a MASSIVE difference. Actually, the essentially non-existent seek time is why SSDs are the shiz and all that.
But as far as the capacity goes, nope, still the same. The 60GB is same on both SSDs and HDDs.
It will be 60. It will be something else after you convert the numer to a different system.And it won't be exactly 60GB. More like 55-56GB.
