Just went 24-2 on Caspian Border and was disconnected from the server before the round ended so I don't get the points for it.... sigh
Do the stats acquired in the beta carry over to the full version?
64 player battles is awesome. Caspian Border is so much better than Metro.
I agree with you about Metro but I've been having a lot of fun with Caspian Border, and I've only used vehicles like twice. I do agree with you about the really bland class system, though.Meh i dunno,Im not all that impressed with BF3 at the moment...Metro is just plain crap,and Caspian border is alright if you can get a Chopper or Jet otherwise your walking for miles if theres no jeep/tanks around.
Unfortunately DICE has said they dont, thats what i read on egm anyway so may be wise to double check other sources,
Just wondering, how is this unfortunate? I know if i got a game in which i am already half way through the ranks, it would suck to know that i only have half way to go. I know it sucks that you lose everything that you have been playing around with, but really, with this game, i am glad i get to do it all over again and experience everything in a new way (when the game is out). Chances are that they are going to change things.
Has anyone else encountered the bug where it won't let you look down the sights/scope unless you reload the weapon again?
Yes. I get around it by switching to my side arm and then back.
Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on single GPU configurations using the AMD Radeon™ HD 6000 and AMD Radeon HD 5000 series of products.
Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on AMD CrossFire™ configurations using the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products.
Just got a 25% off coupon for Origin... I'll definitely be using it on BFBC3
GTX 460 Hawk good for high settings?
You'll need something a bit better than a 460 for 1080p I'm afraid, if you want to max it out. I could probably use another 570 or get a 580 cause I still get only 30fps in some parts![]()
What do you reckon an hd 5830 and a 955BE @stock would get in fps at 1366x768? And what settings?
( i have the 5830 on the way and the 955be in a couple of weeks)
Should do fine.
