So about the time people start coming on for us most days. What is your in game name?
It will most likely be later than that most days, but that is about the time.
My username is Luonce
Well that is probably better, especially for weekends and the such when people generally get on earlier and stay later.
I have whitelisted you, so you should be able to get on. The IP is 85.236.100.50:26456
Probably best you don't now, server is down for maintenance. In case you get on there on your own and are a little overwhelmed, at the spawn you will have a wooden house on one side and a bridge on the other. Go behind the wooden house and there is a train station It has links to all other stations that I've made (still in the process of linking everything, it's my current project), you can have a look around everything there. there should be carts on the tracks already.
So far as building goes, just build anything anywhere so long as you don't break anyone elses stuff
apparently you are already whitelisted turbo![]()
oh fair enough, thanks anyway![]()
Are you not able to get online?
nah im getting refused connection
has the IP changed or is it static ip?
I've worked out why it wouldn't let you connect - I typo'ed the IP
85.236.100.50:26465
is this the same server as before? you do you have your own now?
