zombine210
BAM!
this is my gaming rig :gun:
The shortcuts your talking about is called a Dock. There are several different ones you can get. I use Both ObjectDock, and RocketDock. RocketDock is the one at the bottom. ObjectDock isn't showed in the screen shot because I have it set to only pop up when I put my mouse over it. The rest is RainMeter, which at first may seem complicated, but isn't to hard. It takes time to learn how everything works, and to get it how you want it. I've probably got 10 hours into customizing mine. Thats including spending hours looking for themes, and icons I like though, which I've very picky about.
ObjectDock: http://www.stardock.com/products/objectdock/
ObjectDock addons: http://www.wincustomize.com/explore/objectdock
RocketDock: http://rocketdock.com/
RocketDock addons: http://rocketdock.com/addons/all/popular
RainMeter: http://rainmeter.net/RainCMS/
RainMeter addons: http://customize.org/rainmeter
Help, and instructions:
OD:http://forums.wincustomize.com/82930
RD:http://rocketdock.com/Help/English/
RM:http://rainmeter.net/RainCMS/?q=Rainmeter101
^ I think it comes with Synaptic Package Manager, doesn't it? You can use that instead of the command line.
^ Looks good dude, I like the Dock theme. Which dock is that? I used to have that same wallpaper lol. If your looking for some wallpapers this is personally my favorite site http://wall.alphacoders.com/wallpaper_categories.php
ty sir... yeah you have me hooked now lol, this is actually fun messin aroudn with the dock, and icons and such.... i used the rocketdock like you said and its the Fireblade tribal skin. Looks pretty cool... and ill def check out that website, i change my desktop liek 4 times a week![]()
Yeah it really fun to mess with, so many different things you can do with it.
Heres mine right now, I'll probably keep it like this for a little while.
now what do you use to create where your itunes is, and how you have your disks, and signal strength?
