Pentium 166MHz!!
guess what's so surprising about this? and no... it's not how high my clocks are or the superpi time, that's nothing special.
scooped one up off of ebay i see?
Dice run, can't seem to get the temp below -15.....and whats weird is it says -25 in the bios. But there's no way I'm going to get to 6ghz because I've hit a base clock wall at 246. I tried taking the multiplier down but still won't POST, so I guess 5.6 is all I can get out of it.
Yes, acetone
What kinda pot you got?
A custom one from Bartx, this one here-
http://www.xtremesystems.org/forums/showpost.php?p=4235399&postcount=26
Mine looks exactly like that except it has a few more holes drilled than that.
Even if it's not ''great'', wouldn't it atleast get me to like -50c or something? I hear most hit around -70c on DICE.
Well, what TIM are you running? Most pastes other than ceramique become insulators at subzero temps. Also, are you running just chunks of dice or crushed? Crushed dice tends to work alot better.
do you have another thermometer? because i wouldn't go by what the computer says, -15 is probably all that system can display. you need a thermometer with a k-type probe or something
