WTB Cheap F@H card
G25r8cer
Looking for one of the following
9600gt
9600gso
8800gt
Not looking to spend too much
Edit: May be interested in 2 cards if someone has an older SLI setup
how much would you pay for an xfx 9800gt. its the one that requires a six pin pcie power connector, just fyi
what i paid for it (95) but i dont think ur gonna pay that much cuase they are only $105 new.
i kind of figured, but good luck finding a card. i think aastii had some 8600gt's for sale awhile ago, not sure if he sold them or not.
I believe it's a 9800GTX+, though don't quote me on the differences between them all!
A 9600GSO is a bad little card to fold with. The Asus I bought from voyarerfan cranks out 4,000 to 4,700 PPD all day long. I set the shadder clocks at 1840 and it runs smmoth as silk. You can find them for cheap with a little shopping around.
If you look around for a 9600GSO...make sure you get the 96 stream processors and not the 48 stream processors card. They make both and you'll be dissappointed if you buy the smaller card.
Yeah I have done some research before hand and found that a 9600gso would be the best way to go. Have also done some shopping around and the price all comes out to be as much as a used 8800gt so which, to choose?
