First 700 Gaming Computer Build
wantedelite
So far I ahve this but I need to use the NCIX website since I get discounts there, but I can't find some of the parts at ncix that are at newegg!
Case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119203
Motherboard
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157160
CPU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103649
RAM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231122
GPU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150394
PSU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341017
HDD
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136320
ODD
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151188
Comes to around $670+shipping
please help me build something similar to that but better or similar to that for around 700 CAD and it must be from NCIX!
thanks in advance
Since you're going with an AM3 cpu - you may as well go for an AM3 Motherboard. Your CPU will work in an AM2+ motherboard - but you will limit yourself in the future in case you might want to upgrade later to a quad core.
I can't think of a good reason to build an AM3 Socket CPU with a brand new MOBO that's AM2 or AM2+.
You'd need different RAM if you go with AM3 MOBO.
I can its called a budget and a AM3 board with DDR3 would be very hard to fit that budget.
I don't want ddr3 I want ddr2 ddr3 costs too much and I can't afford that anyone wanna help me out and put that build onto NCIX?
You could get some G.Skill 4GB (2x2) Memory off NewEgg. I'm not gonna find the URL, but it's the light-blue kind. (DDR2)
