Dazzeerr
I've had this problem for a while now and it's been getting worse and worse until now where i can't actually use my computer.
When the problem first started occuring the computer would restart a few times with a strange clicking sound when i turned it on and then eventually get past POST and start-up.
Once it started up I could use the computer for multiple hours without problems, inless i accidently nudged the tower - which made it restart with the noise again. If i shaked the tower lightly it would constantly restart and make the clicking noise. This is why I have a feeling it's a electrical short, something isn't plugged in or something. But i've tried removing and replacing, pushing things in and checked all wires are in properly.
Anyway, it got worse and worse and started restarting randomly when in normal use too, but this could of been because of high bass too, shaking the tower. ^^
I've got a feeling it's one of the harddrives, because i've heard strange clicking noises come from them when they are ready to pop their clogs. I did however try simply unplugging them both and plugging them back in unaware that this would stop Windows XP from booting
My next question, is it the harddrive? Or could it be something else? Any ideas?
Thanks for any input guyysss.
UPDATE:
I know this is a while on now, but I still have the problem xD. Just haven't had time to fix it recently as i've been at work experience.
But anyway, it still happens when I unplug the harddrives, but now I have a feeling it's the motherboard. When it makes the clicking noise the system doesn't shut down, I don't know if this means it isn't the power supply but surely it's less likely?
Also, i've tried to listen to where the sound is coming from, it seems to be near the bottom of the motherboard, around the PCI slots or possibly even coming from the front of the computer where the on, restart button and USB slots are. The clicking noise can be constant when i nudge the computer repeatedly but I just have a feeling it's not the power supply either, doesn't sound like it's coming from the unit, the fan still spins constantly and the whole computer is on, but after a while of clicking the computer does shut down, wait a few moments and restart by itself. I'm really not sure! Haha, any ideas?
- Daz
