Where to get free parts check-ups?
Doop
Hi,
my power supply recently blew out in a power outage even though my computer was off when it happened. I already confirmed the power supply is the problem by switching out my old one, which lets my computer boot up like normal. Which store will do a checkup on the power supply for free? Also, how much should I be spending on a surge protector? Obviously my power strip didn't protect my power supply :|.
Thanks
Well if the computer doesn't boot with the PSU what's the point in getting it checked? It probably be cheaper to just buy a new one.
I know but I just want to make sure there's nothing they can do to repair it or something. Just looking for a place with a quick free checkup
It's not worth repairing a damaged PSU :cool:
Definately this. Don't even think about getting it repaired. Buy a new decent power supply, don't go cheap either. Those cheap surge protectors won't protect much. If you know you have a bad storm coming through or are experiencing abnormal power outages, unplug your equipment to protect it from getting hit.
I want to make sure this never happens again, so buy a decent surge protector ($20 or so?), unplug my stuff from the outlet when I'm not using it, and that's basically all I can do right? Also it wasn't really a big storm or anything, I'm not even sure if a storm caused the problem or if it was something else.
A decent surge protector would cost around $30. But again to be absolutely safe, unplug your equipment if you suspect a storm coming or the power going out and coming back sporadically.
Power off does not cause damage to any electronics. You probably had the most common reason for supply failure - a manufacturing defect.
For example, another had your symptoms. Used speculation to make the same conclusion. I traced their failure to a pullup resistor on a voltage regulator. That resistor had only one function. To boot the regulator during power on. That resistor probably failed months ago during normal operation. But the failure was only noticed months later when it failed to do its only job - during power up.
They had a manufacturing defect. Yours is most likely same.
Meanwhile, that protector claims to protect from transients that are typically not destructive. Spend $25 or $100. Then have a circuit similar to what sells in Wal-Mart for only $7. Those 'adjacent to computer' protectors are profit centers. Read its specification numbers. It does not even claim to protect from the typically destructive surge.
Another completely different device is also called a surge protector. That other surge protector is the only viable solution. And it costs tens of times less money. 'Whole house' protectors come from manufacturers with much better reputations including Siemens, Leviton, Cutler-Hammer, Square D, Keison, ABB, Intermatic, and General Electric. One means everything is protected even from direct lightning strikes.
Either buy a protector that is a profit center. Or buy one that is proven by over 100 years of science and experience. You are asking about protection from something that occurs maybe once every seven years. That is completely different from what typically causes most failures - a manufacturing defect.
One final point. Good luck finding anyone who can repair a supply. I can. But then I have been doing this stuff for decades. Repair only to learn about what caused a failure. Do it only to avert future failures. Most computer techs do not even know how electricity works. Will only replace parts until something works.
Others have recommended not learning why a failure happened. Just replace the supply.
Thanks for the replies everyone, I appreciate the help. One more question: will a surge protector protect me from "power outages"? I don't know what outages do to your electronics, but I'm almost positive that's what killed my PSU. There was a power outage in my neighborhood. Thanks.
To electronics, a power cut off by its switch, the breaker box, or the nuclear power plant all look same. If an outage damages any electronic hardware, then power off also does that damage.
An outage is a reduced voltage. A protector ignores all voltages (does nothing) until voltages exceed something above 330 volts. Again, never take anyone's word for it. Go read that let-through voltage number on its box. Protectors do nothing - remains inert - until AC voltage exceeds its let-through voltage number. Obviously, numbers make it obvious. No protector does anything for an outage.
Your symptoms are better explained by a manufaturing defect. To say more means you must have the PSU repaired.
