Volume Problem
prithive
My motherboard is ASUS P5QL PRO..That motherboard producing very low volume sound..The driver is Realtek...I have installed Windows 7 Ultimate..I set the volume to maximum level in all volume setting. My speaker is sonic gear spectra 200..The problem is volume is not very loud compared to my previous motherboard Gigabyte P31-DS3L...So what I should do? Is there any software to increase the volume?
might seem like it is very obvious, but have you checked the input line to the computer? Mine goes almost mute when it slides out of the computer. Also might be worth a look to see if the speakers have their own volume adjust, as that could cause the issue too.
If not that, then maybe try a cheapo sound card?
Realtek onboard is generally junky or doesn't work right in Windows 7, and they also have a low signal to noise ratio. Get a dedicated card.
In my speaker volume controller, I have set it to maximum..But still not loud..This board producing very low volume compared to other boards..So, how about using an additional sound card? Will it produce louder sound?
Try using another sound card or replacing the cable from the speakers to the computer (if this is possible). Replacing a line is cheaper than buying a sound card. Also, is the volume turned up on any volume controller on the speakers?
