xBoom
Are there any software/app that merges 2 audio outputs (stereo) into 1 audio output (mono) only?
Because I have a headphone that works in mono:
Sounds does come from both sides but BOTH sides plays LEFT SIGNAL ONLY. Example, when I play Counter-Strike, I can hear the enemy from the left side (through both side) but I can't hear the enemy from the right side (through none side). Get it?
I don't want to do anything hardware and I don't care the sound quality/positioning. I just need a software (mononizer
