sm100378
Hi,
Okay, so I have my new build on the second floor with a WMP54g wireless adapter and in the basement I have the cable modem / wireless router wrt54g connected to another desktop. I also use a wireless laptop throughout the house when necessary. Being that my wmp54g keeps disconnecting/reconnecting itself to my home network in WPA, I think I am going to need to run a network cable from the basement to the second floor. The advantage her is that the room in the second floor has a laundry shoot, so I can simply run the cable down that all the floors, and it will then reach the laundry room, which is next to the room of the cable modem/wireless router. I plan on creating wall outlets with this project.
My question: After researching, I am confused with the main differences of switches, hubs, routers, and access points. I know that a hub splits the cable connection and a switch keeps the connection at 100% (hope this makes sense), but what are the others for? Which one would be my best use with what I want to do, which is I dont think I want to use the wireless router as the hub for the connection to do the connection being shared and "weakened", rather than with a switch.
Any help would be very much appreciated.
P.S. I am thinking a setup with the wireless router and the (swtich, bridge, access poin, and hub?)
Bracket on wall:
______wireless router on top________
|_AcessPoint/Hub/Bridge/switch on bottom_|
WIRES LEADING TO BOTH DESKTOPS AND AN INPUT
WIRE COMING IN FROM EXTERIOR OF HOUSE
Bracket on wall:
