surround sound help
When you say "As long as your computer supports 5.1" do you mean the motherboard? and I don't really get when you said 5.1 what is the 5.1? I checked for onboard audio but all it says is
"Audio Chipset Azalia(HDA)
Audio Channels 8 Channels"
where should I check!?
here is the link to my motherboard =) it would be better if you can tell me if it does.
http://www.newegg.com/Product/Product.asp?Item=N82E16813188009
btw this is random. can you show me a link to where I can get internet in this thing?
if it says 8 channels than your fine. He is referring to 5.1 as 5 speakers plus the subwoofer. The subwoofer is always named as .1. So your sound on your motherboard is capable of 7.1 channels. 7 Speakers plus one subwoofer = 8 channels
