surround sound HELP!
CmoAMD
Ok I just got these surround sound headsets.... but it has 3 plugs, center, front, back. My computer only has the sound / mic option. Theres no way I can get all 3 in there? I did come with a bunch of wires....
here's my sound card it has three out put jacks, one for the front one for the back and one for the sub-wolfer, it's inexpensive yet has very good sound quality :) it supports 7.1 surround sound(I think :P )
the thing is i dont think that ure sc supports 5.1 but u could always buy a new one. a splitter might work though...
Use a splitter and you wont have surround sound.
The mobo one... its probably super cheap and gay.
This is the one im getting on my new computer, will it support the center/sub - rear - front holes it needs.
http://www.newegg.com/Product/Produ...MP=OTC-d3alt1me
That would certainly work although you dont need such an expensive setup to run your headphones. An Inexpensive Sound blaster Live! would do the trick.
Yes I know, im just glad to know that sound card will work. I know its overkill for my headset, but I plan on using it for the system for my house.
