Smooth Operator
Just got these speakers ...
http://www.newegg.com/Product/Product.asp?Item=N82E16836121126
They are great but only one problem ...
only the 2 front speakers seem to be working for me !!!
Now it gave me 3 wires to plug in, a green one, an orange (or was it pink? i dunno) one , and a black one. I was able to find a slot for all of them with my mic still pluged in and a free blue slot still there untouched ...
Turned on my speakers and only the 2 front speakers were working ... so i experimented.
I put the black wire where the green one was, and i was able to hear the center speaker. Then i put the orange wire in the green slot , and was able to hear the rear speakers ... now i know the speakers arent broken or anything .
I also went into sound and audio and tried every single speaker setting in there and none of them worked ...
My sound care is called Realtek Ac97 Audio ... if i can get any info on what i have to do to make all the speakers work like they should, id really appreciate it.
thanks for any help i can get.
