Speaker Problem
g4m3rof1337
I moved my speakers and plugged them back in, and now only the two right ones work. I am using the Logitech X-530's 5.1. In the Configuration for the Audio, I set it to 5.1 Channel, and tested it, and all of the speakers work. But when I play music in the Zune Media Player or MediaMonkey, it doesn't work.
Any ideas?
Thanks.
Any ideas?
Thanks.
There's your problem. Most music is recorded in 2.1, so it will come out of your speakers as 2.1. What you need to do is open up a game like CSS and use its "Speaker test" which will tell you if all 5.1 are working. THEN if its still 2.1, yeah, you got a problem. :)
