sound quality poor when played directly from CD/DVD
kumiyer
I just have the onboard soundcard. (Realtek AC97) If I play a song or a video file from my hard disk, it works fine, but if I play a DVD or a CD the sound quality is just poor. I have to crank up the volume at max to hear the sound. Any suggesstions?? Thank you
Check volume controls and see if your CD volume is turned up... Also, many players can play CD Audio without the cable, so you might want to try those. They tend to have MUCH higher quality and work off your wav volume. Media Player Classic is one that doesn't need an audio cable...
I have 2 dvd drives in my computer and both have the same problem. I am assuming that its the cheap onboard soundcard. Thanks for your help
