Sound problems on my computer
yahn
I don't know how similar sound cards are to graphics cards, but, for some reason, my computer frequently freezes when running apps that have 3d sound. In most cases, this would be from games, but it really is not limited to games only.
So, is there something wrong with my computer, or is this a classic lack of sound card issue?
If I buy a sound card, should it fix this problem?
What are you using for sound right now? According to your post I'm assuming you're using on-board audio.
What operating system are you using? This will help get you an answer.
Your configuration of your computer must be wacky.
The common to your problems is the graphic card
go to the manufacturers website and update the driver.
You can look at this it all helps
Also while your computer is in good nick you should download and install superantispyware because when malware gets going you will not be able to access the net.
