Sound problem
chimera123
Hello everyone,
my computer does not detect any speaker jacks plugged in. I just reinstalled windows XP professional on one partition and windows vista 64-bit on another partition (same hard drive). The sound in Vista is working fine, when in XP i have the above mentioned problem.
Can anyone help me?
The drivers are correctly installed. I thought it was a technical error (motherboard), but if the sound is fine under Vista, this is not the case, i belive.
Thank you and best regards.
It sounds like you might not have the drivers as corrrectly installed as you think you do:cool:
What motherboard is this or are you using a sound card?
Thank you for your help, but i belive something was wrong with the windows xp, that i had installed. I installed another copy of Xp, and everything is fine.
I have problems though, with installing two OS's at the same time on the same hard drive - different partitions of course (vista and xp). I formated and reinstalled windows xp for the 10-th time!
Guess i will have to continue working with Windows XP, until i find a solution! :(
thanks again
Well, everybody talks about this new Vista OS :). I want to try it, but i need some programs which are not compatible with Vista at this moment.
The only reason...
