My sound was perfect, then eventually it started to sound static. Along with having a static sound to it, the sound would only come through one ear of my headphones. However, if I wiggled and turned the plug connecting the headphones to the computer a bit, the sound would be clear again. I could listen to music clearly, however if I moved my body a bit, the wire would move with me, and the sound would be static again and only come through in one ear, so I would have to adjust the plug a bit to get the clear sound again.
It wasn’t that the plug wasn’t in all the way, the plug was connected perfectly, however it had a sound to it as if it wasn’t connected right. Eventually it got so worse that I tried getting a new sound card, and the sound worked perfectly. However, it’s been a few months and the problems are coming back. It’s not my headphones either, since it has the same problem with speakers. I was wondering what I could do to fix this and not have the sound be static and only coming in through one ear, with the sound occasionally being clear if I turn the plug the right way to get a ‘connection’.
