sound problem...
Computernewbie
Hi guys,
My new custom pc works like a charm, except for one thing: sound. I have crappy speakers, and when I plugged then in my computer, I seriously had to get them close to my ears to hear the sounds. I didn't really care, since the headphones I own work perfectly with the pc, and are what I mainly use anyways. So I thought the speakers were the problem.
However, this morning, I didn't change anything and the sound stopped coming from the speakers. They are not even recognized by the system, even if they are still plugged. The headphones still work perfectly. I tried the speakers with my mp3 and they work just fine. So the problem is the computer.
What do you think happened, and how can I make the speakers work?
Thanks in advance,
Computernewbie
right click on my computer, select manage
device manager
find audio device
right click and unistall
reboot computer
when it comes back up computer will reinstall the driver
Thanks! I think it worked. The headphones work once again, but the speakers are still a lot weaker than what I know they can be... I mean, when I plug them on my mp3, they can be a bit loud, but on my computer, the sound they make, even at maximum computer sound, is kinda low... Do you know why it does that?
Thanks again,
Computernewbie
