Sound Problem (Any Ideas?)
Xwardos
hi guys, i have a Trust 5.1 sounds system that i've had for about 3 years now and everything was working just fine untile out of the blue, whenever i put the volume up i was experiencing distrotion and the speakers rattle whenever i put it up. the SUB also rattles and doesn't have that kick that it used to have before.
i've downloaded the latest drivers and still no improvement. i also rolled back the the previous drivers to be sure, but still the same.
does anyone have any ippinions?
You may have some hardware problems- you might have blown your amplifier, shaken an internal connection loose, you may not have your connections in back all the way connected, etc. Its prob not a software problem.
