Sound not working help.
Gravite
Ok so today what i did was removing some of the unusual stuff in control panel but after i removed couple of stuff, i went back and turn on my sound but i don't hear anything. When i go into control panel/sound. The sound icon appears to be gray and i cannot move the slider where the volume low/high are. Help please
yeah, the unusual stuff u uninstalled could've been for your Sound drivers. Download them off your compiter make's website. or if youbbuilt your rig, then download them off you your mobo cd, or website. goodluck.,
i dunno this comp is like so old and it was custom built too so and also i can't find any cds that came with it. Help please
gravite, check out this website to get your codecs: http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2543
If the GA-P35-DS3R is ur mobo, in ur sig, then your audio codecs are on that page. if not, go to ur mobo manufacturer website and then download them accordingly.
if ur lazy ;) just post ur mobo up, and someone else would find em.
i worked hard on gettin that link gravite, ur sound bettter work, im usually too lazy to help pple out.
EDIT: no not really just jkin
well sorry to said but thats not the comp with the problem. Its my older comp which i cant seem to find the driver file... it is quite old =(
