andrezbyrd
What is a decent price for a sound card?
Is the second link compatible with the intel core i5?Well it all really depends on your budget,If your wanting a good soundcard for a budget consider this-
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
OR
If you have more to spend-
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010
I havent bought anything yet, I am trying to put together a setup. Hopefully it has one of those.as long as you have a free PCIe slot. Its more motherboard based than CPU.
I dont need quality sound, i plan mainly to do graphic designs
