Troncoso
I haven't made a help thread in quite some time.
I've got an issue at work with my PC. I got a new HP machine (a Z230 SFF) and it has been BSOD'ing ever since I got it (a few months). Sometimes multiple times a day, sometimes only once. Sometimes I'll go a week. What cause it is unknown. It will happen with any program I'm using, or none at all. In fact, it crashed 10 times overnight while it wasn't being used. What we've tried:
1. Re-installing windows
2. Replacing RAM
3. Replace entire machine except SSD and Storage HDD
4. Replace SSD
5. Run without HDD
I've uninstalled absolutely everything but the bare minimum that I need to do my job. There are 2 others at work that use the exact same machine with no issue. (In fact, the old that we swapped with in step 3 is being used by someone else with no issues). I'm not using any software that those two machines aren't using at this point. We've used different Windows install disks in case one was bad.
The BSOD's are all across the board. It's not just a single error or driver. It's several. A couple of the common drivers that have crashed since the last Windows re-install (after replacing the SSD) are tcpip.sys, ntoskrnl.exe, hal.dll, ndis.sys, and wfplwfs.exe. ntoskrnl.exe occurs the most with these errors (among others):
MKODE_EXCEPTION_NOT_HANDLED
INTERRUPT_EXCEPTION_NOT HANDLED
SYSTEM_SERVICE_EXCEPTION
INTERNAL_POWER_ERROR
DRIVER_OVERRAN_STACK_BUFFER
IRQL_NOT_LESS_OR_EQUAL
When I go into work tomorrow I'm going to memtest each memory stick individually (though, the RAM's already been replaced).
I'm at wits end here. IT is also out of ideas. We seriously don't know what to do about this. Unless for some reason this model PC doesn't like SSD's, but that doesn't seem right considering the 2 others that run this exact same setup, 1 with Windows 7, and the other with 8. So, I can't say that it's an Operating System issue, either. As mentioned, HP has already completely replaced the machine. All we did was take the drives from the old and put it in the new one. Even so, at this point, we've replaced the drives, too. The only thing left are the project directories (programming projects) I saved to my SSD before disconnecting the HDD. Those are literally the only constant factor in all of this. About the only left to try is a completely different model PC, I think.
So... does anyone here have any ideas?
2. Replacing RAM
4. Replace SSD
5. Run without HDD
