Okay, so I have an Intel Core 2 Duo Processor E6300 and I'm using a Centurion Cooler Master case. I connected the POWER SW cable to the PW input, the RESET SW to the RES input, the H.D.D. LED cable to the HD input, and the SPEAKER cable to the SPEAK input (basically the cases cables to the F_PANEL). The are 2 single cables tied together. One has a + on it and the other has a - on it--I'm not sure where those go. Also, there is nothing in the PWR_LED input. I think I have everything else set up fine. It started for a couple seconds earlier, then it stopped.
Does anyone have any help they can offer? It would be much appreciated.
Oh, I'm sure I put the + side and the - sides on the right sides.
Thanks in advance.
Thanks in advance.
