BurningSkyline
I've got an old USB to USB cable that I cut one end of and stripped the plastic off the end. Well, I've got a 3 pin fan from an old dell that a wire got caught in the fan and snapped. So the Red and Black wires work, but the yellow is broke so I will have to use some heatshrink tubing on it.
So my question is,
Is the Yellow cable power? or is it ground? I would really like to make a laptop cooler out of some case fans, powered by USB.
If you can understand what I'm trying to explain, good job.
EDIT: just remembered black is ground. Can I get away without having a yellow wire?
So my question is,
