jmurray01
OK, my grandfather called me this morning, and told me his computer (Windows XP) wasn't playing any sound, and the speaker logo that is used to adjust the volume wasn't visible in the task bar.
So, I went down there to have a look, and right enough, the logo isn't there, no sound is being played, and it is saying "No Audio Device".
I've checked the hardware and it is all enabled, so what is wrong!?
I'm going back down tomorrow, so if I get a solution I'll try to fix it again then.
Thanks in advance.
Thanks in advance.
