need help on notebook Wireless Network Connection
EC3388
My notebook used to be able to see and connect to my home wireless network. Recently my notebook cannot see any available wireless networks. When trying to connect to available networks through advanced bottom, there is nothing(no network) there.
So I did the following:
1. Select the Start button on the Task Bar.
2. Select Run.
3. Type cmd.exe.
4. When the DOS command prompt window opens,Type ipconfig.
Then my display on Window IP configuration information are :
Ethernet adapter Wireless Network Connection 2:
Media State.......................... : Media disconnected
Ethernet adapter Local Area Connection:
And I'm confused on what to do next to correct the problem.
Any help is appreciated.
Right click my network places. In the window right click the wireless connection an select "enable". If it is not disabled, I don't know whats wrong...
