I have just bought a new USB notebook sound adapter for $40. So now the line out plug for speakers is connected via this USB adapter. However before I start using it, I would like to know is there a need to disable the existing built in sound board? How shall I go about doing it? Some says change motherboard BIOS settings, where some says configure via device manager, where some others says add/remove hardware wizard. Also, last but not least will I still be able to use the volume control icon on my taskbar?
I need the know the best options. Thanks.
