My New Parts..
Takumi
Hello I'm new and heres my parts I'm getting and I also need your feedbacks Thanks. :)
Here they are....
Motherboard: ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD
# CPU Type: Phenom II / Athlon X4 / Athlon X3 / Athlon X2
# FSB: 2600MHz Hyper Transport (5200 MT/s)
# South Bridge: AMD SB750
# Number of Memory Slots: 4×240pin
# Memory Standard: DDR3 1600
# Maximum Memory Supported: 16GB
# PCI Express 2.0 x16: 4 x PCI Express 2.0 x16 (dual X16, triple X16/X8/X8, or Quad X8)
# SATA 3Gb/s: 5
Hard Drive: Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
# Cache: 32MB
# Form Factor: 3.5"
# Features: High Performance Electronics Architecture Dual processor - Twice the processing power to maximize performance. 32 MB cache - Bigger, faster cache means faster performance. Rock Solid Mechanical Architecture StableTrac - The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking, during read and write operations. NoTouch
Video Card: EVGA GeForce GTX 295 1792MB Ready SLI Supported Video Card
# Chipset Manufacturer: NVIDIA
# Core clock: 576MHz
# Stream Processors: 480 (240 x 2) processing cores
# Memory Clock: 1998MHz
# DirectX: DirectX 10
# OpenGL: OpenGL 3.0
# HDMI: 1
# DVI: 2
Power Supply: NZXT Performance Power PP800 800W ATX 12V 2.2V SLI Ready CrossFire Ready Power Supply
# Fans: 120mm Fan @ 1900 RPM
# Main Connector: 20+4Pin
# +12V Rails: 4
# PCI-E Connectors: 2 x 6Pin, 2 x 6+2Pin
# Power Good Signal: 100-500ms
# Hold-up Time: 16ms min.
# Efficiency: Up to 85 %
# Over Voltage Protection: Yes
Memory: Kingston HyperX 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop
# Cas Latency: 8
# Timing: 8-8-8-24
# Voltage: 1.65V
# Multi-channel Kit: Triple Channel Kit
# Heat Spreader: Yes
# Recommend Use: High Performance or Gaming Memory
(I know the memory is designed for intel...)
CPU : AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor
# Series: Phenom II X4
# Hyper Transports: 3600MHz
# L1 Cache: 4 x 128KB
# L2 Cache: 4 x 512KB
# L3 Cache: 6MB
# Manufacturing Tech: 45 nm
# Voltage: 0.875-1.5V
OS: Microsoft Windows Vista Ultimate SP1 64-bit for System Builders
It's about $1,664.44
NZXT Tempest
I got excited there for a second, thought I was gonna get to see a whole bunch of pictures of the boxes and stuff...I get all gitty about those.:D
phenom II 940 wont work on AM3 Motherboard.. YOU WOULD HAVE TO GET A P2X3 710,720, X4 810 there are some good am3 boards on the egg just check them out
