Hello all, I have searched this site but have came up with no solution. I have multiple problems with my connections. I am not on a router and am connected to a Sprint DSL modem. I have tried uninstalling everything, disconnecting all wires, resetting TCP/IP settings, installed a SP2 patch for limited connectivity, and nothing has worked. My problems:
1. Limited or no connectivity concerning my LAN connection.
2. Can't access firewall settings in either connection (LAN or ISP). Says "Due to an unidentified problem, Windows cannot display Windows Firewall settings" whenever I click on the settings button on the firewall tab.
3. Can actually connect to the internet, but it only stays connected for at most 5 minutes. Then most times I have to reboot and reset the modem to get it to work again.
4. When I am connected now it messes up my land line and I can't use the phones.
Anyone have any idea what's causing this? Thanks for the help.
