Origin Saint
Well-Known Member
Hi all, I recently attained a ton of old computer equipment and I was wondering if there is a way to use some of it externally. Example being, I have some CD-ROM drives, and I was wanting to use them externally. I realize that they will either need some type of makeshift outlet plug (a definite last resort), or battery powered. I will post some pictures of the things I'm wanting to try and use externally.
The first picture is a old micro speaker. It has the normal power cords to attach to a motherboard and a normal 3.5mm audio jack cord. I was thinking maybe stripping the wires and connecting them to a series of batteries and then just connect the speaker jack to any device I want to listen to. Would this work? Or am I trying to push a little far here.
The second is a USB cord from a Dell. The USB end would show in the front of the computer case and the back would plug into the motherboard. Is there any way to rig this so that I could plug one end into a computer and use it as a USB extender/hub?
The third picture is a old CD-ROM drive. I was wondering it there was a way to power this up and be able to plug it into a computer and use it as a external CD drive.
The fourth picture is a small sound piece out of a Dell as well. The front would be showing out of the front of the case, and you would plug in your speaker/headphones and microphone here. Is there a way to use this to have extra jacks for something?
As I said, this is all just used and abused left over junk parts that would have been thrown away, and I got for free, so I just wanted to see if I could find a use for some of it. Thanks for any help and assistance in advance.
