bigbondfan
my network has been giving me hastle ever since i got my computer. sometimes it works, sometimes it doesn't. i've gone through the useless xp help + support thing about five times, it fails to fix my problems. i must have gone through at least three books on setting it up and i've tried three ethernet network cards and the network is still as sh*t as ever . I know i have set it up correctly, following instructions. i have a ethernet hub with 2 other computers on it.
i wanted my network to connect to the internet, but the host doesn't seem to connect to the network. All it does is thinks up a new ip address (i've tried setting my own, but that doesn't work either) for about a minute and then the network says it's connected but the internet doesn't work, and i can't get access to any shared files on the client. I try the repair button but it comes up with an error that is poorly explained with a cancel button that doesn't work.
-the two clients can't access the internet or shared files or printers on the host, but they can access each other
-the host cannot browse the clients and says limited or no connectivity after about a minute of "aquiring network address".
Does anyone now how to resolve my network problem?
Here's some info i grabbed of everest home edition about my networked computers:
My computer is a client:
AMD Athlon 64 3500+, 1024MB RAM, Windows XP Home SP2
1GBit Ethernet card "NVIDIA nForce Networking Controller" ethernet
-100mbs,
-MTU=1500 bytes,
-IP/Subnet Mask=169.254.235.97/255.255.0.0,
-DHCP=255.255.255.255
The host computer:
AMD Athlon 64 3400+, 2048mb ram, xp home sp2
SiS 900-Based PCI Fast Ethernet Adapter
-100mbs,
-MTU=1500 bytes,
-IP/Subnet Mask=169.254.119.74/255.255.0.0
The Hub:
NetGear Dual Speed Hub DS104 (http://www.netgear.com/products/details/DS104.php)
-100mbs
-4 sockets (3 are used)
the host is plugged into the first socket, mine is in the second and the other is in the third. the forth is not used. the host computer has a usb adsl broadband modem.
the wires are ethernet and were custom made to the right length at our local computer shop (ingeniously named "The Computer Shop") and they have worked before. i've checked the wires for breaks and bends, but they all look fine. i've even tried different ones.
-100mbs,
-MTU=1500 bytes,
The host computer:
-100mbs,
-MTU=1500 bytes,
The Hub:
-100mbs
