Juddering Sound Urgent Help, Insane I'm Going!
Tahninial
I have a laptop with the following stats:
XP Home Sp2
Intel Pentium M 2.0GHz Processor (755 Chipset I Think)
OnBoard Realtek AC'97 Audio (Disabled)
SoundBlaster Live! 24-Bit External Sound Card
128mb ATI M11 Radeon 9700 Graphics Card
1GB of DDR PC2700 RAM
100GB HDD (5400rpm), 42% Free
The laptop worked like a dream when I got it in October, a few weeks ago I noticed the audio playback was getting a bit jerky, like when my old desktop can't cope with many tasks. This was doing it in mid-play however and on WMP. It wasn't so bad as to make me think about looking into it then though. However about a month ago I wanted to produce an audio track with Acid Pro (which previously ran smoothly) and I realised that when running any two sounds together it wouldnt do it without contantly cutting in and out providing this jerky, choppy playback. Also recording with a microphone was hopeless and recording anything at all left big skips where what i nthought was the hardware was skipping out.
As I couldnt remember doing anything specific that may have triggered it, mainly as i didnt think about it when it first started, I tried the following things I found that worked/suggested for similar errors with no success, (or seemingly an imporvement until it happens again):
* Scanned for viruses with up-to-date McAfee AND Norton
* Scanned for spyware with Spybot AND Adaware
* Fixed all registry errors found with Registry Mechanic
* Removed the USB TV Stick I thought may be conflicting
* Uninstalled and reinstalled and/or updated Realtek drivers
* Disabled Devices on Device Manager that I am not using (e.g. onboard modem)
* Tried reducing the graphics card hardware acceleration to no difference, so i changed it back
* Removed my USB wireless Mouse which may have coincided with start
* Did a full defrag of the HDD
Follwing a suggestion someone else was given, but also because my card wasnt quality enough for what i would have liked anyway, I purchased an external soundcard (as detailed above) but the problem persisted. I do not see this as a waste because I now can use external speakers (stupid laptop has a headphones out buit its on the front and awkward to keep hooking it up) and better yet its all conencted via USB so it leave other things free. What was even more annoying is that even the windows startup sound is crackly. I have also found stuff on SoundBlasters help that are presumably things to change in the BIOS and stuff rekating to upgrading the BIOS as a certain factor that is in the bios is reuired to support some drivers but I havent looked too far into that as it seems like I am clutching at straws.
In addition to this, I upgraded my Video Drivers to Omega Drivers. This was after the nproblem has started and was so I could play The Sims 2 without Graphical Error, as far as I know playing The Sims, (which I havent done for a couple of weeks but was while the probelm was ongoing) plays perfectly without constant sound glitch, however other games I play and things like AOL sounds have started displaying the playback glitching symptoms.
For a little more background, my RAM never goes below 650MB (after instaling McAfee anyway, it was never under 700MB when I had the useless Norton Ati-virus) but a constant hogger of RAM is svhost, which i understand runs many important things. I'm pretty sure it never used to be the thing using the most resources however. Now its without fail the most memory using thing. I did notice that soemtimes the system CPU Usage is quite high espeically when opening programs when its around 90%, this seems wrong especially for what I understand are decent hardware.
In case anyone requests one, as im hoping the answer lies within this, here is my report from HiJackThis:
Logfile of HijackThis v1.99.1
Scan saved at 19:56:00, on 13/01/2006
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
C:\Program Files\Intel\Wireless\Bin\ZcfgSvc.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\Intel\Wireless\Bin\1XConfig.exe
C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
C:\WINDOWS\system32\CTsvcCDA.EXE
c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
C:\Program Files\Intel\Wireless\Bin\OProtSvc.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe
C:\Program Files\Intel\Wireless\Bin\EOUWiz.exe
C:\Program Files\Java\jre1.5.0_05\bin\jusched.exe
C:\Program Files\RF Wireless Mouse\cm20.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
c:\PROGRA~1\mcafee.com\vso\mcshield.exe
C:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
C:\PROGRA~1\mcafee.com\agent\mcagent.exe
c:\progra~1\mcafee.com\vso\mcvsescn.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Creative\SBLive 24-Bit External\Surround Mixer\CTSysVol.exe
C:\WINDOWS\system32\RunDll32.exe
C:\Program Files\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe
C:\Program Files\Creative\MediaSource\RemoteControl\RCMan.EXE
C:\Program Files\Creative\MediaSource\Go\CTCMSGo.exe
C:\Program Files\TechSmith\SnagIt 7\SnagIt32.exe
C:\Program Files\TechSmith\SnagIt 7\TSCHelp.exe
c:\progra~1\mcafee.com\vso\mcvsftsn.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\AIM\aim.exe
C:\Program Files\Windows Media Player\wmplayer.exe
C:\Program Files\AOL 9.0a\waol.exe
C:\Program Files\AOL 9.0a\shellmon.exe
C:\Program Files\Common Files\AOL\aoltpspd.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\Creative\MediaSource\RemoteControl\OSDMenu.EXE
C:\Documents and Settings\Dan\Desktop\Desktop Crap\HijackThis1991.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://tahninial.livejournal.com/friends
O2 - BHO: HelperObject Class - {00C6482D-C502-44C8-8409-FCE54AD9C208} - C:\Program Files\TechSmith\SnagIt 7\SnagItBHO.dll
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: SnagIt - {8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3} - C:\Program Files\TechSmith\SnagIt 7\SnagItIEAddin.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - c:\progra~1\mcafee.com\vso\mcvsshl.dll
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [IntelZeroConfig] C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe
O4 - HKLM\..\Run: [IntelWireless] C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [EOUApp] C:\Program Files\Intel\Wireless\Bin\EOUWiz.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_05\bin\jusched.exe
O4 - HKLM\..\Run: [Start RF Wireless Mouse] C:\Program Files\RF Wireless Mouse\cm20.exe
O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [VSOCheckTask] "c:\PROGRA~1\mcafee.com\vso\mcmnhdlr.exe" /checktask
O4 - HKLM\..\Run: [VirusScan Online] "c:\PROGRA~1\mcafee.com\vso\mcvsshld.exe"
O4 - HKLM\..\Run: [MCAgentExe] c:\PROGRA~1\mcafee.com\agent\mcagent.exe
O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\mcafee.com\agent\mcupdate.exe
O4 - HKLM\..\Run: [WinPatrol] C:\PROGRA~1\BILLPS~1\WINPAT~1\winpatrol.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [CTSysVol] C:\Program Files\Creative\SBLive 24-Bit External\Surround Mixer\CTSysVol.exe /r
O4 - HKLM\..\Run: [SbUsb AudCtrl] RunDll32 sbusbdll.dll,RCMonitor
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [AtiPTA] atiptaxx.exe
O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
O4 - HKCU\..\Run: [FreeRAM XP] "C:\Program Files\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe" -win
O4 - HKCU\..\Run: [RemoteCenter] C:\Program Files\Creative\MediaSource\RemoteControl\RCMan.EXE
O4 - HKCU\..\Run: [Creative MediaSource Go] C:\Program Files\Creative\MediaSource\Go\CTCMSGo.exe /SCB
O4 - Startup: Yahoo! Widget Engine.lnk = C:\Program Files\Yahoo!\WidgetEngine\YahooWidgetEngine.exe
O4 - Global Startup: SnagIt 7.lnk = C:\Program Files\TechSmith\SnagIt 7\SnagIt32.exe
O8 - Extra context menu item: &AOL Toolbar search - res://C:\Program Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
O8 - Extra context menu item: &Download with &DAP - C:\Program Files\DAP\dapextie.htm
O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: &Translate English Word - res://c:\program files\google\GoogleToolbar1.dll/cmwordtrans.html
O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar1.dll/cmcache.html
O8 - Extra context menu item: Copy to Semagic - C:\Program Files\Semagic\copy.htm
O8 - Extra context menu item: Download &all with DAP - C:\Program Files\DAP\dapextie2.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Semagic - C:\Program Files\Semagic\link.htm
O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Translate Page into English - res://c:\program files\google\GoogleToolbar1.dll/cmtrans.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_05\bin\npjpi150_05.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_05\bin\npjpi150_05.dll
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O9 - Extra button: GloPhone - {C9B8ABB6-1CC3-4957-9CA3-053036B2EE3A} - C:\Program Files\The Globe\GloPhone\glophone.exe
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} (QDiagAOLCCUpdateObj Class) - http://aolcc.aolsvc.aol.co.uk/computerchec...kup/qdiagcc.cab
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.av.aolsvc.co.uk/molbin/sha...84/mcinsctl.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/...b?1128783406570
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdat...b?1129017860813
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2005111...all/xscan53.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMesse...pDownloader.cab
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.av.aolsvc.co.uk/molbin/sha...,21/mcgdmgr.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{45F80768-1C76-4263-BC31-36F225F3B295}: NameServer = 205.188.146.145
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O20 - Winlogon Notify: IntelWireless - C:\Program Files\Intel\Wireless\Bin\LgNotify.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: AOL Connectivity Service (AOL ACS) - America Online, Inc. - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
O23 - Service: EvtEng - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: McAfee.com McShield (McShield) - Unknown owner - c:\PROGRA~1\mcafee.com\vso\mcshield.exe
O23 - Service: McAfee SecurityCenter Update Manager (mcupdmgr.exe) - Networks Associates Technology, Inc - C:\PROGRA~1\McAfee.com\Agent\mcupdmgr.exe
O23 - Service: McAfee.com VirusScan Online Realtime Engine (MCVSRte) - Networks Associates Technology, Inc - c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
O23 - Service: OwnershipProtocol - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\OProtSvc.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: RegSrvc - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
As I said it used to work like a dream, there arent any hardware conflicts that the computer can find, it happens on either sound card I use and it's not a sound card driver update issue.
Thanks in advance!!!
Well first of all, people typically don't read really long posts, so just for future reference, a shorter version will get a quicker response. Secondly, you have basically tried everything that I have thought of, but I would suggest turning off anything that has to do with AOL or AIM, then if you are willing, turn off McAfee cause it uses a lot of resources. I uninstalled it from mine and used other programs cause it just slowed my machine down so much. All I can think to say is try reinstalling all the sound card drivers again ( I know you already did so, but just for kicks and giggles) and if that doesn't work, reinstall windows. If you reinstall and you still have problems, could be a mobo issue
oh, and what the heck is SOUNDMAN.EXE? I'd say try to ge rid of it too if it isn't something you know should be running
