L leron8 New Member Jun 1, 2008 #1 so i have a soundblaster sound card and of course the integrated audio... now i would like to know if i can use both at the same time so i could have multiple mics and multiple speakers?? i have tried but only the soundblaster works....
cohen New Member Jun 1, 2008 #2 It's either one or the other. You have to set one card to be the default.
cohen New Member Jun 2, 2008 #4 leron8 said: ohhh ok i guess i'll just use the soundblaster... thanks. Click to expand... Yes - if you want you can get a splitter.... You can something a little smaller than this... but it is an example.
L leron8 New Member Jun 3, 2008 #5 ohhh yeah i've used those before... i think i'll use those for some recording...
L leron8 New Member Jun 4, 2008 #7 i play the guitar and in a rock band and we want to record some of the songs we play...
cohen New Member Jun 4, 2008 #8 leron8 said: i play the guitar and in a rock band and we want to record some of the songs we play... Click to expand... Go into a mixer and then into the computer.
